vpn some subnet works others dont
phamthecong
Hi All,
we have a site-to-site VPN (PIX <-> Cisco 7200). 1 local network and 4 remote subnets are in the ACLs. The VPN works fine with 2 remote subnets but does not work for the other 2.
work means we can send traffic from local to remote site.
not work means we can not send traffic from local to remote. Dont see IPSEC SA when show crypto ipsec sa.
could someone help please
Tao
andrew.prince
Level 10
Level 10
Check your interesting traffic ACL and your NAT & no-nat ACL's to make sure they all match.
HTH>
Hi Andrew,
We have checked the ACLs many times, they are identical but in reverse source and destination. We use static NAT one-to-one. and they are correct.
DO you have any ideas?
thanks,
Tao
If you NAT before you encrypt - you need to make sure you are not natting again after, before encryption.
Post your config for review - remove sensitive information.
