WLAN Guest Access logs with WLC
Jun 14th, 2010
Hi all,
If I set up a guest access network based on WLC & WLC anchor (with or without WCS), do you know if it is possible to log the clients'sessions (we want to have dest IP/url & timestamps) ? If yes, how could we handle it ?
Thank you
leejohns Tue, 06/15/2010 - 12:38
No, you would need some other device like Websense in order to be able to view that information.  The WLCs are not going to be able to provide you with that as they do not log wireless traffic in that manner.
jgauthray Wed, 06/16/2010 - 00:46
Ok Thanks
Problem is that I need to log clients URLs, and if I use a UTM/websense to log that traffic it is hard to get who asked for a specific URL : web authentication is made on WLC, http logging is made on UTM and there is no correlation between that two logs files.
It seems it is possible to get something like that with an architecture : WLC + NGS + ASA. Is there any easier/smaller solution (if I need to deploy such a solution in a small network)?
Thank you
Related Content
Trending Topics - Security & Network
