06-14-2010 06:43 AM - edited 03-04-2019 08:46 AM
I have static IP on a DSL router and want to access 4 routers on the lan ( ssh or telnet )
For one router, I can do a static NAT but how can I access other 3 routers from Internet.
ST
Solved! Go to Solution.
06-14-2010 06:48 AM
You can do port forwarding based on the port numbers on the DSL router e.g.
Wan interface IP address port 3000 forward it to Router 1 ip address port 23
Wan interface IP address port 3001 forward it to Router 2 ip address port 23
Wan interface IP address port 3002 forward it to Router 3 ip address port 23
Wan interface IP address port 3003 forward it to Router 4 ip address port 23
so when you telnet wan interface ip address it will forward according to the port numbers where the telnet was received on the DSL router
telnet 1.2.3.4 3000 >> Goes to R1
telnet 1.2.3.4 3001 >> Goes to R2
and So on...
Hope this helps
Hitesh Vinzoda
Pls rate useful posts
06-14-2010 06:48 AM
and So on...
Hope this helps
Hitesh Vinzoda
