Limit hours utilization by Directory Number
Answered Question
Jun 14th, 2010
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
My Customer have the CallManager 5.1.3 and would like know if is possible to limit hours the utilization directory number. I Verified that possible create the Time scheduled as form to limit, but, this feature limit the period and not  hours quantity. Anobody have idea?
Wilson
Correct Answer by Jaime Valencia about 6 years 11 months ago
CUCM has no method to do this, you would need to write down a custom TCL script which connect to some sort of info repository to update the info of how many minutes have been used vs how many are available and then allow/deny the call.
This also would need you to use H323.
I believe there might be a 3rd party app for this but I'm not sure.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 06/14/2010 - 08:34
  • Cisco Employee,
  • Hall of Fame,
    2011
java
wilsonsant Mon, 06/14/2010 - 09:08
Hi Javalenc,
Thank You for answer.
Wilson
