Chetan Kumar Ress Mon, 06/14/2010 - 08:56
  • Silver, 250 points or more
As i had configured GRE tunnel over PPP Multi-Link. It was working fine.
So in DMVPN also it should not create an issue or any prerequisite for same.
Only think is you need to take care of  your routing part the basic to reach end to end.
Chetan kumar
belovell Mon, 06/14/2010 - 09:11
DMVPN is agnostic to the underlying physical links. MLPPP should work fine.
-Ben
tj.mitchell Mon, 06/14/2010 - 09:19
  • Bronze, 100 points or more
I don't see a reason why not..
It would create a tunnel through the multilink interface, just like any other configuration.
TJM
