06-14-2010 09:58 AM - edited 03-04-2019 08:46 AM
Hi Everyone,
I have a 7204 VXR Router, all the ports are being used except for one Fa3/0. I am about to create three networks, 192.168.3.0/24, 192.168.4.0/24 and 192.168.5.0/24. I'm thinking of creating sub-interfaces on Fa3/0 but before I do that, does anyone know what is the maximum sub-interface I can create on a Fast Ethernet port and what is the dis-advantage of creating sub-interfaces?
Thanks.
06-14-2010 10:16 AM
Read the following link on Router IDB's.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a0080094322.shtml
As far as disadvantages to using the sub interface idea, I'd suppose that high traffic volumes would give you issues.
Consider some form of throttling.
06-14-2010 10:27 AM
1] maximum sub-interface
---> Creating Sub-Interface on Fast Ether is nothing but associating with VLAN ID. The number of VLAN that you can create is the number of interface .
2] dis-advantage of creating sub-interfaces
---> Dis-Advantage is nothing but you need to take care of CPU , It will utilize CPU as you will add number of interface.
Chetan Kumar
06-14-2010 10:29 AM
What is the command to show the current CPU utilization?
THanks
Alfred
06-14-2010 10:39 AM
Below are the command to see CPU utilization
1] show processes cpu
2] show processes cpu history
Chetan Kumar
