Federico Coto F... Mon, 06/14/2010 - 11:29
  • Green, 3000 points or more
You can summarize as follows:
192.2.0.0/21
However, the above includes other subnets as 192.2.0.x, 192.2.6.x, 192.2.7.x
So, if you see overlapping problems, better not summarize.
If the above won't cause problems, go for it.
Federico.
Giuseppe Larosa Mon, 06/14/2010 - 11:34
  • Hall of Fame,
    Founding Member
Hello Just,
you need to look at the third byte write it in binary
1 = 0000 0|001
3 = 0000 0|011
5 = 0000 0|101
you need to look at the common bits from the LEFT, that are the first 5 bits before '|' this means the inclusive aggregate (that includes also other subnets) is:
moving three bits to the left from /24 boundary  : 24-3 = 21 this is the prefix length
192.2.0.0/21
if you look at summary routes that do not include other subnets the answer is negative: there is no way to aggregate these subnets without including other ones because they are not contigous
the fact that all of them have the last bit set to 1 in common is not useful
Hope to help
Giuseppe
