Show and Share publishing fails
Jun 14th, 2010
New SnS install. Saving files locally until the storage server is ready. I create a video and when I try to publish I get the following error:
The deployment status at time of recording was as follows: Deployment Job ID: a219e855-fe2f-43ac-b7d2-57197f3a583b
Publisher: superuser
Job Type: Deployment
State: ERROR
Status description: dms.core.deployment.filetransfer.file.not.found: Unable to locate the specified file to be transferred
Percentage completion: 0
The following endpoints are being deployed to:
Endpoint ID: e4b8fc36-c8ef-42f6-84bc-48212287195b
State: ERROR
The following content are being deployed to this endpoint:
Content ID: C-859b1b03-21f0-4026-be5f-593f581b203c:1
State: ERROR
The following assets are being deployed for this content:
Asset ID "A-268645d4-f0ce-48e0-8c5a-4be64342d629" status: ERROR
File name: null
Progress: 0/0 bytes transferred
Status description: Unable to find file at source path: /content/vportal/C-859b1b03-21f0-4026-be5f-593f581b203c_1/1276541026863WebCamCapture.flv
I've changed the hostname on the SnS server, rebooted, changed back, re-paired, etc. None of it seemed to make a difference. Next step I'm thinking is to reinstall SnS from scratch.
Anyone else run into this?
Tomas De Leon Tue, 06/15/2010 - 11:30
Is this a VMware Demo Image or the Actual SnS Appliance?
Please provide the following Screenshots:
- From the AAI interface, provide the "Show Info" screen (For the DMM & SnS)
- From the AAI interface, provide the "Date and Time Settings" screen (For the DMM & SnS)
- From the AAI interface, provide the "Appliance Control-->Pair Appliance-->(DMM\SnS)"
- From the SnS Web Admin, provide the "Administration-->Setup-->Show and Share" screen
- From the SnS Wen Admin, provide the "Manage-->User Roles" for the Username of the one
  experiencing the issues.
Can you access the URL (from your Browser)
http:///content/vportal/C-859b1b03-21f0-4026-be5f-593f581b203c_1/1276541026863WebCamCapture.flv
directly?
What Browser Application & Version are you using when the error occurs?
T.
Jon Nelson Wed, 06/16/2010 - 07:13
Actual SnS appliance
directly?
No. The page errors out. I tried http://server:8443/ & http://server:8080/ both error out.
Safari 4.0.5 & MacOS 10.6.3 & Flash 10.1
For some reason I cannot get past the flash applet with Firefox 3.6.3 on MacOS 10.6.3. I upgraded to Flash 10.1 hoping to remedy that, but it didn't matter.
An addiitional note: I can upload a video just fine.
Thanks for the help Tom!
-Jon
Tomas De Leon Wed, 06/16/2010 - 10:27
I cannot reproduce the failure.  I use the same
Client setup and my webcam deployments work fine.
So, I need you to perform the following:
Go to the AAI of the Show and Share (SnS)
and perform the following:
-- Select APPLIANCE_CONTROL--> Select LOGGING_OPTIONS
    -- Select CLEAN_LOGS--> CLEAN_TOMCAT_LOGS
    -- Then Select CHANGE_LOG_LEVEL--> DEBUG
After Tomcat Restarts on the SnS (can be verified either by the DMM-Admin-Services Tab on DMM or
via simple Web Access of the SnS directly), Please Reproduce the WEBCAM deployment error.
-- Please screen capture any errors on the Web Deployment screen or My Videos Status Window
After the Deployment failure occurs, Return to the AAI of the SnS and get the SYSLOG files
for the SnS.
    -- Select GET_SYSLOG
After retrieving the SYSLOG files from the SnS, Please provide the following Log Files:
../var/log/apache-tomcat/catalina.out.2010-xx-xx  (The Latest file# which should be the largest file size)
./var/log/apache-tomcat/vp/DeployHandler.log
./var/log/apache-tomcat/vp/DeployStatus.log
./var/log/apache-tomcat/vp/ServiceRequests.log
./var/log/apache-tomcat/vp/ViewerHandler.log
T.
Jon Nelson Wed, 06/16/2010 - 13:41
Tom,
I sent you a PM with the information you requested.
Jon
Related Content
