QuickVPN; Vista X64; RVS4000;
Jun 14th, 2010
I am trying to configure a client to work with a RVS4000 using QuickVPN.  The client is running Windows Vista x64.  I have turned the firewall (Windows builtin) on/off and entered custom rules in the advanced firewall allowing both inbound and outbound ICMPv4 traffic.
The client hangs at "Verifying Network..." and then I receive the infamous "Remote Gateway is not responding..." dialog.
The interesting aspect is this:  I am running VMWare on the same client and have a guest version of Windows XP32 running.  Using the same version of QuickVPN 1.4.0.5 I have no problems.  Therefore the intervening hardware is not the issue.
Following is the log text from the Vista x64 attempt:
2010/06/14 14:29:51 [STATUS]OS Version: Windows Vista
2010/06/14 14:29:51 [STATUS]Windows Firewall Domain Profile Settings: ON
2010/06/14 14:29:51 [STATUS]Windows Firewall Private Profile Settings: ON
2010/06/14 14:29:52 [STATUS]One network interface detected with IP address 192.168.150.62
2010/06/14 14:29:52 [STATUS]Connecting...
2010/06/14 14:29:52 [STATUS]Connecting to remote gateway with IP address: server1.rach.net
2010/06/14 14:29:56 [STATUS]Remote gateway was reached by https ...
2010/06/14 14:29:56 [STATUS]Provisioning...
2010/06/14 14:30:05 [STATUS]Success to connect.
2010/06/14 14:30:05 [STATUS]Tunnel is configured. Ping test is about to start.
2010/06/14 14:30:05 [STATUS]Verifying Network...
2010/06/14 14:30:11 [WARNING]Failed to ping remote VPN Router!
2010/06/14 14:30:14 [WARNING]Failed to ping remote VPN Router!
2010/06/14 14:30:17 [WARNING]Failed to ping remote VPN Router!
2010/06/14 14:30:18 [WARNING]Failed to ping remote VPN Router!
2010/06/14 14:30:19 [WARNING]Failed to ping remote VPN Router!
2010/06/14 14:30:22 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2010/06/14 14:30:23 [STATUS]Disconnecting...
2010/06/14 14:30:29 [STATUS]Success to disconnect.
Has anyone succesfully opened a VPN tunnel with QuickVPN and Vista x64?
michaelrach Mon, 06/14/2010 - 13:22
I apologize for posting this in the wrong heading, it should be under "Small Business Routers" where I
have moved it.  Please disregard this discussion.
