UCCX v5 and Oracle 10g
Answered Question
Jun 14th, 2010
Our client with CCX v5 (Premium) wants to data dip in Oracle 10g. Will it work? If so should I install the Oracle client on the CCX server? Is it supported?
Solomon
Correct Answer by Aaron Harrison about 7 years 1 month ago
It's the only way - you need the ODBC drivers, or it won't work.
It's been a while since I used Oracle, so I would start by installing the client on a PC and testing ODBC connectivity from there. I'd be aiming to install the smallest amount of software possible (i seem to remember the Oracle software being quite large) so do a custom install and try to just install the ODBC drivers and no extra client tools.
Aaron
Please rate helpful posts...
Overall Rating: 5 (3 ratings)
Walter Solano Mon, 06/14/2010 - 17:11
  • Gold, 750 points or more
Hello Solomon,
At this point the only Data Base that its supported for UCCX is SQL 2000, and needs to be the Cisco version that its ship by Cisco, any other Database will not be supported.
This is the software compatibility matrix
http://tools.cisco.com/squish/f7BAe
Please rate this post if was helpful
Walter Solano
CCVP, Cisco UCCX Specialist
Gabriel Saavedra Mon, 06/14/2010 - 17:49
  • Silver, 250 points or more
Hi Solomon,
If you have a premium license, you can query your enterprise database from your scripts to obtain data and then manage it in the script. The supported Enterprise Databases are shown in the pdf that Walter posted. Just search for your UCCX version and then in the column that says Enterprise Database. To tell you more all UCCX 5.X versions support Oracle 10g R2, Oracle 10g XE.
Gabriel.
Walter Solano Mon, 06/14/2010 - 17:54
That its correct 5 points for you, sorry I missunderstand the question jajaja.
In this case you don't need to install the Oracle client in the UCCX server, what you will need to configure is a ODBC connection between both severs after that you will be able to query the Oracle from the script without any issue.
Walter Solano
solomonluke Mon, 06/14/2010 - 20:47
Ok so Oracle 10G is supported. ODBC does not connect unless I install Oracle client on the CCX server. Is this the correct and supported way to connect to Oracle database?
Solomon
Correct Answer
Aaron Harrison Tue, 06/15/2010 - 06:20
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
