ICMP Problem
Answered Question
Jun 14th, 2010
my Topology as below :
Host1------>FW1<-------------------->FW2------->Host 2
                                 Default Route
My FW 1and FW 2 are back to back connect and both site already configure default route to point each other, however i unable to ping the FW 2 inside interface IP address and the Host 2 IP, from Host 2 ping to FW1 Inside interface also cannot and even the Host 1.
The attachment is the configuration i configured please help!!!!
thks
-gilbert
On FW1 change:-
access-list outside_in extended permit ip any any - REMOVE THIS
access-list outside_in extended permit icmp any any  - REMOVE THIS
access-list outside_in extended permit icmp any any echo  - REMOVE THIS
access-list outside_in extended permit icmp any any echo-reply - KEEP THIS
access-list outside_1_cryptomap extended permit ip 192.168.2.0 255.255.255.0 remote 255.255.255.0 - DELETE
access-list inside_nat0_outbound extended permit ip 192.168.2.0 255.255.255.0 remote 255.255.255.0 - DELETE
Put the below in:-
access-list outside_1_cryptomap extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
On FW2 change:-
access-list outside_1_cryptomap extended permit ip 192.168.3.0 255.255.255.0 remote 255.255.255.0 - DELETE
access-list inside_nat0_outbound extended permit ip 192.168.3.0 255.255.255.0 remote 255.255.255.0 - DELETE
access-list outside_1_cryptomap_1 extended permit ip 192.168.3.0 255.255.255.0 remote 255.255.255.0 - DELETE
Add the below:-
access-list inside_nat0_outbound extended permit ip 192.168.3.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list outside_1_cryptomap_1 extended permit ip 192.168.3.0 255.255.255.0 192.168.2.0 255.255.255.0
Overall Rating: 5 (1 ratings)
gilbertcsc Tue, 06/15/2010 - 09:20
Hi ,
I already make changes on the Nat part, i'm able to get ping now however i try configure site to site vpn through wizard it can't work.
The attachment is the config file thks
-gilbert
Correct Answer
On FW1 change:-
Put the below in:-
On FW2 change:-
Add the below:-
