06-14-2010 11:58 PM - edited 03-04-2019 08:46 AM
I was just wondering, since most PCs motherboards nowadays do not have a RS232 connection, what do you do for that? I tried a USB to serial cable and couldn't get it to work even though it says the driver was installed correctly. Actually, I've never heard of anyone who made it work.
Solved! Go to Solution.
06-15-2010 02:10 AM
I was using an PCMCIA card to connect to serial ports in the past.
But it was also not 100% reliable.
So I'm keeping saying my managers:
I need a notebook with a RS-232 port on motherboard!
BR,
Milan
06-15-2010 02:29 AM
Hi Feng,
I have a USB-to-Serial cable made by Sweex and I can confirm that it works for me using both Windows XP and Windows 7 & PuTTY. I think it uses a Prolific chipset.
In the lab and the comms rooms, I have some old Cisco 2511RJ routers. These have 8 or 16 terminal ports - you can pick them up on ebay now for very little.
Kevin
06-15-2010 02:10 AM
BR,
Milan
06-15-2010 02:29 AM
Hi Feng,
Kevin
06-15-2010 11:14 AM
I have been using a USB to serial adapter by Keyspan and have had good success with it.
Rick
06-16-2010 01:38 AM
I'm using a usb to serial adapter from ATEN, and I have no problem with that adapter.
However, be sure to always use the same usb-port on the computer, otherwise You can be forced to change the comport-number.
/Mikael
