blaxucisco Tue, 06/15/2010 - 16:03
Hi shuman,
cisco nac supports wsus, sms or sccm.
thank you
shuman13x Tue, 06/15/2010 - 19:52
Hi blaxucisco,
Thanks for the info. May i know is there a doc on how to configure sms/sccm remediation? Even from guide 4.7.2, i only noticed Windows Updates and WSUS requirement. Do I need to user Launch Programs requirement for sms/sccm?
Thanks.
Faisal Sehbai Tue, 06/15/2010 - 20:00
  • Gold, 750 points or more
There isn't any 'native' support for those products. You can however check for registry keys or files that are present on your client systems that might be associated with those products. Natively CCA can check for WSUS and WU only for Windows updates.
HTH,
Faisal
blaxucisco Tue, 06/15/2010 - 20:36
Hi Shuman,
in my understanding, WSUS is integrated part of the SMS and SCCM. we don't need to do any extra thing for SMS and SCCM. WSUS related configuration on the NAC will work.
Faisal, any  advice???
Thank you
Faisal Sehbai Wed, 06/16/2010 - 15:51
I'm not sure how tightly integrated SCCM/SMS and WSUS are, but when I said natively, I meant that CCA only has the requirement types for WSUS. For the others you'll have to rely on File Checks and/or Registry Checks.
HTH,
Faisal
Related Content
