cisco catalyst 2690 switch vlanTable
szabotamas
I have a cisco catalyst 2690 switch.
I want monitoring IP, MAC, and Port Address.
I use this docu: http://docstore.mik.ua/orelly/perl/sysadmin/ch10_03.htm
This works great:
htvtef7-nagios:/ # snmptranslate -On BRIDGE-MIB:dot1dTpFdbTable
.1.3.6.1.2.1.17.4.3
snmpwalk -c tef7snmp@761 -v 2c 10.76.1.7 .1.3.6.1.2.1.17.4.3
htvtef7-nagios:/ # snmptranslate -On BRIDGE-MIB:dot1dBasePortTable
.1.3.6.1.2.1.17.1.4
snmpwalk -c tef7snmp@761 -v 2c 10.76.1.7 .1.3.6.1.2.1.17.1.4
htvtef7-nagios:/ # snmptranslate -On CISCO-STACK-MIB:vlanTable
.1.3.6.1.4.1.9.5.1.9.2
But I get a error:
htvtef7-nagios:/ # snmpwalk -c tef7snmp -v 2c 10.76.1.7 .1.3.6.1.4.1.9.5.1.9.2
SNMPv2-SMI::enterprises.9.5.1.9.2 = No Such Object available on this agent at this OID
Switch config:
snmp-server community testament RO
snmp-server community tef7snmp RO
snmp-server location XYZ
snmp-server contact MR.XYZ
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps cluster
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon
snmp-server enable traps mac-notification
snmp-server enable traps copy-config
snmp-server enable traps config
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
snmp-server host XXX.XXX.XXX.XXX public
snmp-server host YYY.YYY.YYY.YYY  tef7snmp
What did I do wrong?
THX!
yjdabear
Assuming you're referring to a 2960, I don't think you did something "wrong" in terms of those snmp-server configs. The IOS and/or 2960 combo simply might not have support for the CISCO-STACK-MIB. To verify, post the output of "show snmp mib" from the switch, in enable mode. Or, check the Cisco Feature Navigator: http://tools.cisco.com/ITDIT/CFN/
Thx for the replay!
I use on the switch c2960-lanbasek9-mz.122-25.SEE3.bin (IOS),
the Cisco Feature Navigator say, this IOS support the CISCO-STACK-MIB:
http://tools.cisco.com/ITDIT/MIBS/MainServlet?ReleaseSel=0&PlatformSel=0&fsSel=0&IMAGE_NAME=c2960-lanbasek9-mz.122-25.SEE3.bin&SUBMIT2=Submit&IMAGE_ID=816103
In show snmp mib I could not find the vlanTable. See the attachment.
I du not understand!
It does have vlanTable support. The following in the "show snmp mib" output are what you're looking for (where "cisco" is equivalent to ".1.3.6.1.4.1.9")
cisco.5.1.9.2.1.1 => 1.3.6.1.4.1.9.5.1.9.2.1.1 / vlanIndex
cisco.5.1.9.2.1.2 => 1.3.6.1.4.1.9.5.1.9.2.1.2 / vlanSpantreeEnable
cisco.5.1.9.2.1.3 => 1.3.6.1.4.1.9.5.1.9.2.1.3 / vlanIfIndex
You can look up what each means here;
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.4.1.9.5.1.9.2.1.1&translate=Translate
So what you want to do is
snmpwalk .1.3.6.1.4.1.9.5.1.9.2.1.1
snmpwalk .1.3.6.1.4.1.9.5.1.9.2.1.2
snmpwalk .1.3.6.1.4.1.9.5.1.9.2.1.3
then correlate across thpse results, as well as the other OIDs in your original post.
did not work
htvtef7-nagios:/usr/share/snmp/mibs # snmpwalk -v 2c -c tef7snmp 10.76.1.7 .1.3.6.1.4.1.9.5.1.9.2.1.1
SNMPv2-SMI::enterprises.9.5.1.9.2.1.1 = No Such Instance currently exists at this OID
htvtef7-nagios:/usr/share/snmp/mibs # snmpwalk -v 2c -c tef7snmp 10.76.1.7 .1.3.6.1.4.1.9.5.1.9.2.1.2
SNMPv2-SMI::enterprises.9.5.1.9.2.1.2 = No Such Instance currently exists at this OID
htvtef7-nagios:/usr/share/snmp/mibs # snmpwalk -v 2c -c tef7snmp 10.76.1.7 .1.3.6.1.4.1.9.5.1.9.2.1.3
SNMPv2-SMI::enterprises.9.5.1.9.2.1.3 = No Such Instance currently exists at this OID
cisco snmp mibs V1 and V2 have a difference?
ftp://ftp-sj.cisco.com/pub/mibs/v1
ftp://ftp-sj.cisco.com/pub/mibs/v2
