Call Manager 5.X , insufficient Hard Disk Space
Jun 15th, 2010
Hello everyone !
i just want to make a question, maybe silly for a lot of you.
I received an alarm from the CUOM, saying that there is not sufficient hard disk space to my systems.
The CM version is 5.X., how can i find the un-needed files and delete them ?
Thanks a lot
Aaron Harrison Tue, 06/15/2010 - 04:18
Which partition is reported as being full?
As the system is a locked-down appliance it can be difficult to clear out files unless they are log files. I recall there were several bugs on CCM 5 which resulted in the system running low on disk space; it would probably be wise to open a TAC case.
TAC will be able to advise what to do to fix the system - they can get root access to the server and deleted problem files, and will be able to advise whether you need to upgrade to prevent the problem recurring.
Please rate helpful posts...
PS - this is the Contact Center forum - you would probably get a faster response to CallManager questions from the IP Telephony forum.
Related Content
