Cisco RVS4000 port forwarding and VPN
Jun 15th, 2010
Hi everyone,
I have an issue to install a VPN for my company. Basically I need a VPN tunnel between two branches and the ability to remotly connect with laptops from outside. I think that 2 Cisco RVS4000 are the solution for now, but i can't make the VPN tunnel work. I tryed in local and they work quite well, but when i connect the routers to the Thomson gt585v7 for give them the internet connection, nothing seem work fine. Basically i got this device in front of the cisco gateway and i don't know what to forward to the cisco router to make the vpn work. I tryed to forward the port for https and the port 8080 and the http port 80. I can't access to the router remote setup anyway. I read that i can't have a NAT function before the cisco router to enable the VPN, but i don't think it's possible to pass a public IP directly to the WAN port of the cisco gateway.
To let you know better my configuration is       LAN -> ciscoRVS4000 -> Thomson gt585v7 -> Internet <- Thomson gt585v7 <- ciscoRVS4000 <- LAN
And i wanted to know how many users can connect from outside ( and if is possible connect someone from outside )
thanks a lot for your help
Draiden85 Tue, 06/15/2010 - 03:24
I forgot to tell you that i manage to forward an apache server that is in the lan so basically the port forwarding for the two devices is working.
Draiden85 Tue, 06/15/2010 - 05:26
I tryed to follow that guides, but the problem is that i can't get the public IP, so i can't sele
ct the router from outside the lan. I tryed
to setup a gateway but i can't find it in the router configuration menu.
Draiden85 Tue, 06/15/2010 - 07:25
For adding informations the Thomson is a router itself, and so i'm stucked betweet the public ip and a natted one
Public IP -> internal ip -> cisco external assigned by thomson -> internal ip assigned by cisco
And on the other side is the same i can't turn off the thomson routing to use it as a normal modem.
