option Bandwith in interface Tunnel for QoS
georgd
Config in Cisco3845 IOS c3845-advipservicesk9-mz.124-24.T2.bin:
policy-map child
class TOS1
    bandwidth percent 45
policy-map parent
class class-default
    shape average 2000000
  service-policy child
interface Tunnel1201
bandwidth 300
tunnel bandwidth transmit 270
tunnel bandwidth receive 270
service-policy output parent
bandwidth 2000
tunnel bandwidth transmit 2000
tunnel bandwidth receive 2000
show policy-map interface tu 1201
Tunnel1201
  Service-policy output: parent
    Class-map: class-default (match-any)
      233 packets, 103581 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 233/32154
      shape (average) cir 1000000, bc 4000, be 4000
      target shape rate 1000000
      Service-policy : child
        Class-map: TOS1 (match-all)
          0 packets, 0 bytes
          Match:  precedence 1
          Queueing
          (pkts output/bytes output) 0/0
          bandwidth 45% (540 kbps)
sh policy-map interface tu 1202
Tunnel1202
      264 packets, 122815 bytes
      Match: any
      Queueing
      (pkts output/bytes output) 264/36432
          0 packets, 0 bytes
          Match:  precedence 1
          Queueing
Qwestion:
Why the same bandwith (540 kbps) on both interfaces?
belovell
The bandwidth statement in your QoS config is a percentage of the shaper in your parent class not the "bandwidth xxxx" on the interface. So it will be the same on both interfaces. This is really how it should be as the "bandwidth xxxx" statement on the interface has no bearing on QoS or traffic. It just changes the EIGRP bandwidth metric for the tunnel.
-Ben
5 Replies 5
belovell
-Ben
policy-map child
class TOS1
policy-map parent-2
class class-default
    shape average 3000000
bandwidth 2000
qos pre-classify
tunnel mode ipsec ipv4
tunnel protection ipsec profile AES
service-policy output parent-2
sh policy-map interface tu 1201
Tunnel1201
  Service-policy output: parent-2
      3 packets, 527 bytes
      Match: any
      Queueing
      (pkts output/bytes output) 3/414
      shape (average) cir 3000000, bc 12000, be 12000
      target shape rate 3000000
          0 packets, 0 bytes
          Match:  precedence 1
          Queueing
bandwith 45%=540kbps
bandwith 100%=540/45*100=1200kbps
the "shape" command has no effect, if shape > 1200kbps.
tunnel source gigabitEthernet 0/0.20
It's bug or feature.
On IOS 124-9.T this is not!
georgd@hotmail.ru
I'm not sure I completely understand this. What version are you trying this on?
bandwidth 45% (540 kbps) <--- this does seem wrong as your shape rate has increased.
Did you edit the policy in place? Have you tried removing and re-adding the policy-map?
-Ben
