IOS not supported to HWIC-2ce1 pri card
Jun 15th, 2010
        I have 3845 router using IOS flash:c3845-advsecurityk9-mz.124-3c.bin .  after that we have install HWIC-2E1-PRI and change the ios to
1) c3845-advsecurityk9-mz.124-20.T5
2) c3845-advsecurityk9-mz.124-24.T3
But the ios not supported to hwic card , card is ok . so pls suggest the sepcific IOS to 3845 router Support hwic card.
shahansas Wed, 06/16/2010 - 04:06
Hi Mayank,
Please go to cisco website and find the tool "Direct Configuration Tool", the enter the your product name and try to configure your product with new IOS image.
I am sure, there is an issue with feature set on IOS, so select the different feature set IOS and let the minimum release 12.(4)T
Hope this resolves your issue.
Shahid Ansari
