Send Syslog messages to multiple SYSLOG servers
leonnoble
We are have two syslog servers defined, however we notice that the ACS only sends the syslogs to one server and will only send to the other in a failure scenario, which is a standard operation across all platforms. However we have a requirement for the ACS to send syslogs to both servers simultaneously, is there a configuration option for this?
Many Thanks
Leon Noble
6 Replies 6
gaboughanem
hi
what version of ACS you are using? ACS 5.0 and 5.1 can support 2 syslog server simultaneously .
regards,
We are 5.1, but are unable to find the setting that allows this, can you help.
Many Thanks
You can do the following:
1) Create a remote log target for your syslog server atSystem Administration > Configuration > Log Configuration > Remote Log Targets
2) Configure the log categories that should be enabled to eb sent to this log target.
Go toSystem Administration > Configuration > Log Configuration > Logging Categories > Global
Select a specifc category and then look at "Remote Syslog Target" tab.
For each category that you want sent to your syslog server select the remote log target in the "
That has worked perfectly, thanks again for the help.
Waris Hussain
I am not sure if there is an option but what is the ACS version you are talking about  ?
Waris Hussain
Hi Waris,
Not sure if you have seen the post from jrabinow, but the solution that was provided by jrabinow works for our requirement. It is version 5.1
Kind Regards
