regexp problem with TCL Script
Answered Question
Jun 15th, 2010
I'm having some troubles with my regexp in a tcl script.
My switch 3750 doesn't want to compil my script if there is [0-9] or \d in my script ...
After a show energywise children I'm doing:
set intd [ regexp -all -line -inline "1\/0\/." $result ]
($result is the show energywise cli result)
It work with interfaces from 1/0/1to9.
set intd [ regexp -all -line -inline "1\/0\/.." $result ]
It work with interfaces from 1/0/10to48
but i need to have all interfaces in the same regexp, why "1\/0\/[0-9]+" or "1\/0\/\d+" don't work ?
Here is my ios : c3750-ipservicesk9-mz.122-53.SE1.bin
Anybody have a clue ?
Correct Answer by Joe Clarke about 6 years 8 months ago
Replace the "" with {}.  That is, you need to escape the '[' if you want to use it, or include it in literal "{}".  For example:
set intd [ regexp -all -line -inline {1\/0\/[0-9]+.} $result ]
Overall Rating: 5 (1 ratings)
maintenance.artesys Tue, 06/15/2010 - 07:58
Maybe need more details, my eem version is :
Embedded Event Manager Version 3.20
Component Versions:
eem: (v320_throttle)2.1.50
eem-gold: (v320_throttle)1.0.4
eem-call-home: (v320_throttle)1.0.4
Event Detectors:
Name                Version   Node        Type
application         01.00     node0/0     RP
mat                 01.00     node0/0     RP
neighbor-discovery  01.00     node0/0     RP
identity            01.00     node0/0     RP
syslog              01.00     node0/0     RP
routing             03.00     node0/0     RP
cli                 01.00     node0/0     RP
counter             01.00     node0/0     RP
interface           01.00     node0/0     RP
ioswdsysmon         01.00     node0/0     RP
none                01.00     node0/0     RP
oir                 01.00     node0/0     RP
snmp                01.00     node0/0     RP
snmp-object         01.00     node0/0     RP
ipsla               01.00     node0/0     RP
snmp-notification   01.00     node0/0     RP
timer               01.00     node0/0     RP
rpc                 01.00     node0/0     RP
My problem is here :
if [catch {cli_exec $cli(fd) "show ene chi | include SEP"} result] {
    error $result $errorInfo
    puts "$result"
foreach intf [ regexp -all -line -inline "00.{10}" $result ] {   /* this line is good, it save the mac address of an equipment*/
  puts "Mac-address:$intf"
  puts "test:$intd"
So my code works but the regexp "1\/0\/.." give me the interface from 1/0/1 to 9 betwin { }.
If i try "1\/0\/[0-9]+" or "1\/0\/\d+", it returns nothing, and I have an error at compilation.
Correct Answer
Joe Clarke Tue, 06/15/2010 - 11:47
