Muhammad Irfan Tue, 06/15/2010 - 06:50
follwoing error we are getting,
Error from the authentication subsytem
hr=0x8004054B (the specified domain neither does not exist or could not be contacted.|0D\X0A)
David Hailey Tue, 06/15/2010 - 06:55
  • Purple, 4500 points or more
If you have not done so already, try to use the IP address of Unity in the URL as opposed to the name of the server (i.e., "ciscounity" in the URL above).
Hailey
Aaron Harrison Tue, 06/15/2010 - 06:57
  • Community Spotlight Award,
    Member's Choice, May 2015
I tend to set up the Unity boxes to use anonymous authentication - this bypasses any Windows authentication problems, and allows you to put in your username/password etc into a form. I find this much more reliable than the default single-sign on....
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity/5x/installation/guide/umexnofo/5xcuigumenofo100.html#wp1567419
Aaron
Please rate helpful posts...
