06-15-2010 07:38 AM - edited 03-15-2019 11:15 PM
hi all,
I got a weird questions. on the 8961, 5 programmable buttons on the left, and 5 sessions keys on the right of the screen. I don't think I can program any of the sessions key, can I? if not, how to swap those two sets of keys, ie. move the 5 programmable keys to the right and 5 sessions keys to the left??
On Cisco product decription for it, it does say it can be configured on the left or right side of screen.
thanks
Solved! Go to Solution.
06-15-2010 10:22 AM
Hi Minghui,
This is accomplished by using a specific "locale" as shown below;
(The position of session buttons may be reversed with that of programmable feature buttons on phones using a locale with a right-to-left reading orientation, such as Hebrew and Arabic.)
(The position of programmable feature buttons may be reversed with that of session buttons on phones using a locale with a right-to-left reading orientation, such as Hebrew and Arabic.)
Cheers!
Rob
Please support CSC Helps Haiti
06-16-2010 05:34 AM
Hi Minghui,
You are most welcome my friend
That is correct, you would have to change to a "locale" that uses
a "right- to - left" display.
Cheers!
Rob
06-15-2010 10:22 AM
Hi Minghui,
Cheers!
Rob
06-15-2010 06:30 PM
Hi Rob,
Thanks for the info. this is all for English users. I guess there is no way to swap those buttons without changing language??
cheers,
06-16-2010 05:34 AM
Hi Minghui,
Cheers!
Rob
