Cisco 2901 + PAT
Answered Question
Jun 15th, 2010
I've been trying to determine what the performance would be like using a Cisco 2901 using PAT. I don't plan on doing anything too fancy (Forwarding a couple of ports and such). I'm looking for something that can do a minimum of 50 Mbps both directions. Does anyone have a suggestion on where I can go and find information on performance under these conditions?
I found the SMARTnet info. It is CON-SNT-2901. --- Many Thanks.
Jonathan
Correct Answer by Edison Ortiz about 7 years 1 week ago
Hi Jonathan,
Performance depends on several factors:
  • The type of application and its type of traffic
  • Whether IP addresses are embedded
  • Exchange and inspection of multiple messages
  • Source port required
  • The number of translations
  • Other applications running at the time
  • The type of hardware and processor
  • WAN/LAN Speed and congestion on any of the lines.
You can find the performance numbers from the 2901 without running any services at this URL
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
You can take these numbers and calculate around 85% to 95% if you were to just run NAT with forwarding a couple of ports.
Edison
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Tue, 06/15/2010 - 09:35
  • Hall of Fame,
    Founding Member
Hi Jonathan,
Edison
