OSPF LSA type 1, link ID meaning
Answered Question
Jun 15th, 2010
Hi !
I remember I had already posted this question on news groups but the discussion as been removed (it's look like too older discussion)
I had read : Authorized Self-Study Guide Building Scalable Cisco Internetwork (BSCI) for my preparation to the exam.  In the OSPF chapter the author as wrote on page 230 :
Each type 1 LSA is identified by the originating router's ID in the link-state ID field.
Each of the router's links (interfaces) is defined as one of four types: type 1, 2, 3, or 4. The LSA includes a link ID field to identify what is on the other end of the link; depending on the link type, the link ID field has different meanings. Type 1 LSA link types and their link ID meanings are described in
Table 5-2.
Table 5-2. LSA Type 1 (Router LSA) Link Types
Link TypeDescriptionLink ID
1Point-to-point connection to another router Neighbor router ID
2Connection to a transit network DR's interface address
3Connection to a stub network IP network/subnet number
4Virtual LinkNeighbor router ID
During my revision this part on the text let me confused, I try to find the same part of information in the OSPF Network Desing Solution book from Cisco Press, but I had find nothing about it.
Someone can give to me some more detailed about the LSA Type 1 and link ID meaning ?
Thanks a lot !
Correct Answer by Giuseppe Larosa about 6 years 8 months ago
Hello Christien,
a router LSA is a data structure that has an owner/ originator so it has a "title" = OSPF router-id of originating router.
The router LSA has some bit flags used as options for example to signal if the router is acting as ASBR (= injecting external routes into OSPF domain).
After the title, and the flags there is a list of links that are:
in the same area to which the Router LSA refers.
For each of these links there is a small data structure made of the fields described in the table
so there is a link type and a link-id
The  objective of link state database is to provide an exact image of links within the area
So if the link is point-to-point to allow remote routers in the same area to figure who is on the other end of the link the link id is the OSPF router-id of neighbor.
For multiaccess segment in order to correctly draw the lan segment the remote router needs to know :
on non  DR devices (state DRother) a pointer to DR IP address on segment is provided
on DR device a list of OSPF router-ids of devices connected to the LAN segment is provided and the IP subnet of the segment in corresponding network LSA
(edit: this is actually a type 2 network LSA on DR  device not a router LSA sorry for this but it is part of the picture )
This allows to a remote device to know what routers are connected to a LAN segment!
if no OSPF neighbor is seen on the interface, this is a leaf and the router needs to advertise the IP subnet associated to it
for those very rare cases where a virtual link has to be used it is like a point-to-point link so the link-id is the other endpoint OSPF router-id
Hope to  help
Giuseppe
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 06/15/2010 - 09:54
LSA Type 1 is basically the router saying to everyone that its running OSPF and its OSPF interfaces. The Link ID is equivalent to the Router-ID which often is the loopback interface or if the loopback is missing, the highest IP address will be selected. You can also alter this process by manually entering the router-id information under the OSPF process.
Edison.
Correct Answer
Giuseppe Larosa Tue, 06/15/2010 - 09:56
Hello Christien,
Hope to  help
Giuseppe
