Ganesh Hariharan Wed, 06/16/2010 - 07:48
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hii Experts,
Wht is the command to stop the Broadcast traffic from remote site connected on Switch Port (L2 port).
Storm-Control can be used to limit, or to set thresholds for different types of traffic (Broadcast, Multicast and Unicast) on a specific interface you choose (or that you´re asked for).You can set your threshold to whatever the top level that you want, and the traffic will be limit to that.
The following example will enable Unicast Storm-Control on a switch port with an 89% rising suppression level and a 67% falling suppression (remember, falling suppression can only be configured in 3560). It´ll also enable Broadcast Storm-Control on a port to a level of 20%. When the Broadcast exceeds the configured level of 20% of the total available bandwidth of the port within the traffic-storm-control interval, the switch drops all broadcast traffic until the end of the traffic-storm-control interval:
interface gigabitethernet0/1
storm-control unicast level 89 67
storm-control broadcast level 20
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
netbeginner Thu, 06/17/2010 - 10:47
Hi Ganesh & Guise,
Implemented the command on L3 switch gig interface (Cisco 4500 series).
interface GigabitEthernet4/36
switchport trunk allowed vlan 2,4,6
switchport mode trunk
speed 100
duplex full
udld port aggressive
storm-control broadcast level 0.00
We have given Level % "0",  As per understanding If we configure the 0% level then there should not be any single broadcast on the interface. But even after this we are getting broadcast on the interface.
5 minute input rate 807000 bits/sec, 326 packets/sec
5 minute output rate 2729000 bits/sec, 391 packets/sec
    5514045 packets input, 1802450404 bytes, 0 no buffer
    Received 1712 broadcasts (1109 multicast)
Please help to stop the total broadcast on Gig.
Ganesh Hariharan Fri, 06/18/2010 - 00:11
Hi Ganesh & Guise,
speed 100
duplex full
Check out the below link for more information
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25sg/configuration/guide/bcastsup.html#wp1026643
Hope to Help !!
Ganesh.H
