NAT on ASA ver 8.3
Jun 15th, 2010
Hello:
I am replacing my PIX with a new ASA.  I decided to upgrade the IOS to the latest version 8.3.  NAT was one of the things which was completely redesigned.  On my old PIX I had the below command.  This allowed hosts on my private network to access my DMZ.  I have looked through a few NAT guides but have not found referances to this command.
static (inside,dmz) 192.168.0.0 192.168.0.0 netmask 255.255.0.0 0 0
Does anyone know how to input this?
Harrison Midkiff
Jon Marshall Tue, 06/15/2010 - 12:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Harrison Midkiff
Harrison
asa(config)# object network inside-subnet-identity
asa(config-network-object)# subnet 192.168.0.0 255.255.0.0
asa(config-network-object)# object network inside-subnet
asa(config-network-object)# nat (inside,dmz) static inside-subnet-identity
see the config guide for full details -
ASA NAT config guide
Jon
HMidkiff Tue, 06/15/2010 - 12:58
Jon:
Thanks for replying to my post.
I am still digging through the guide.  For the subnet command I will have to added all my internal networks.  On my deployment I am trying to be ultra secure and only specify the networks which can go out.  There does not seem to be a way to tie the subnet command into an "access-list" or "object-group"?  Just curious if you know....
Harrison
