1240 to lightweight with 2112
Answered Question
Jun 15th, 2010
Hi folks. I have 9 x 1242 AG, I am trying to convert to lightweight but no success.
The AP's are :
Product/Model Number:AIR-AP1242AG-A-K9
Top Assembly Serial Number:FTX1045B6V3
System Software Filename:c1240-k9w7-tar.124-10b.JDA
System Software Version:12.4(10b)JDA
Bootloader Version:12.3(7)JA1
I am using c1240-rcvk9w8-tar.124-21a.JA2.tar as the upgrade image.
Before I go into more details,  please would anyone confirm that this is ok to do ? I have a sinking feeling that it's not going to be possible, which is a biiig problem.
Many thanks,
NM
Correct Answer by leejohns about 7 years 2 weeks ago
Neil,
I would highly recommend the following:
Only a single network connection from the 2100 to the switched network.
Don't have any APs plugged directly into the 2100, put them on a network switch instead.
The reasons for this is that the 2100s, although they have multiple ports, are not switches. In fact, every interface on the 2100s uses the same MAC address. There are several bugs filed against the 2100 for ARP failing, DHCP not working, PoE not working, APs not joining the WLC, etc when plugged directly into the ports on the WLC b/c of the single MAC address design.
You will have a much better experience with the 2100 series WLCs if you follow those two guidelines.
Lee
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 06/15/2010 - 11:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Neil,
The good news is that the 1242 is fully supported for the Autonomous to
LWAPP conversion process We have always used the LWAPP Upgrade
Tool for this process to capture the SSC, but I'm sure that Leo or one of the other
great NetPros here can help you further with your process.
Upgrading Autonomous Cisco Aironet Access Points to Lightweight Mode
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp176272
LWAPP Upgrade Tool Troubleshoot Tips
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072d9a1.shtml#prob
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
neilmac Tue, 06/15/2010 - 12:10
Hi, Rob.
Thanks for the heads up.
I have actually managed to get one to upgrade now, the key was to run the ftp on a different machine to the one running the upgrade tool.
Thanks again !
Neil
neilmac Tue, 06/15/2010 - 12:15
Um - one more question -
The WLC 2112 ports should work just like a switch ?
On of the AP's on poe doesn't see the network when plugged into the controller, oif i plug other devices in they don't see eachoter. Are these ports (Apart form the interface port) just for LWAPP ?
Neil
Correct Answer
leejohns Tue, 06/15/2010 - 12:30
  • Cisco Employee,
Neil,
Lee
