Warning message
dhcpd_rcv_callback received udp error 2
Jun 15th, 2010
Running an ASA5505, tried 7.2.4(30) and (33), set up a dhcp relay server, as of this morning clients couldn't obtain new dhcp leases.  Did a "debug dhcprelay event 255" at the console, saw this message which doesn't seem to be documented anywhere:
Did a packet trace on the outside interface of the ASA, saw DHCP discover/offer packets being sent forwarded from the ASA and then received back from the DHCP server as expected.  Changed to a different DHCP server and the error went away, clients were able to obtain leases.
The problem appears to be with the DHCP server itself, but the server admin can't find anything wrong with it.  Wondering if anyone can clarify what the above error message means so it might help us find the problem on the server.
Mike
brquinn Thu, 06/24/2010 - 12:19
  • Bronze, 100 points or more
Mike,
In other cases I've seen with this error message, the DHCP server was misbehaving in some way. Expand your capture on the ASA to capture all traffic (not just udp traffic) to the dhcp server. Check to make sure the server is not also sending back an ICMP port unreachable for each DHCP Discover.
You can also do 'clear dhcprelay stat', then re-attempt obtaining an IP address, and collect 'show dhcprelay stat'. Are the values for DHCP UDP Unreachable Errors or DHCP Other UDP Errors increasing?
Brendan
ippolito Mon, 06/28/2010 - 09:34
Thanks for the reply.  Turns out that the dhcp server had recently been given a second IP address.  It was still listening for dhcp requests using the old IP address, but replying to the ASA using the new address.  The two IP's were similar enough that I didn't notice it in the packet trace, but that was what the ASA was choking on.  Too bad the error message wasn't a little friendlier -- something like "received unsolicited reply from dhcp server with ip address x.x.x.x", instead of "dhcpd_rcv_callback received udp error 2".
