ACE 4710 Appliance end-to-end SSL
Answered Question
Jun 15th, 2010
Am I able to use a port other than 443 to the servers in a end to end SSL config?  For example, 443 to the users and 8443 to the servers?
Dave
Correct Answer by Sean Merrow about 6 years 9 months ago
Hi Dave,
Sure that's not a problem at all.  Just make sure you add the 8443 after the rserver name in the serverfarm configuration
serverfarm host REAL_SERVERS
  probe HTTPS-KEEPALIVE
  rserver SERVER_01 8443
    inservice
  rserver SERVER_02 8443
    inservice
Hope this helps,
Sean
Overall Rating: 5 (1 ratings)
Correct Answer
Sean Merrow Thu, 06/17/2010 - 05:47
  • Silver, 250 points or more
Hi Dave,
    inservice
    inservice
Hope this helps,
Sean
