Local Network Address Change
Jun 15th, 2010
I have a WRV210 router. I can see it and configure it either manually or through the setup program. If I change the router address from to and reboot both the router and my computer I can access the internet, ipconfig says that is my gateway, but I cannot log on to the router at The MS PD tool says that the connection was rejected by the target. Reset router more than once with the same result.
Rajdeep Parmar Wed, 06/16/2010 - 12:34
nothing u have to add that ip renge in your network.
how ????
open local area network -- properites - - TCP /IP -- Select properties again ..
it will open a new window.. where  u can config ur ip address manually & DCHP ...
select use the following ip add . ( ur subnet mas k) ( GW ) ( DNS)
then  bottom of the page u can see one advance button click on that one  put any ip addres of that range .. like ..192.168.3 .240
save it n reboot ur router ...
n now try to open in web page....
Rajdeep P .
