Connection services
Answered Question
Jun 15th, 2010
Correct Answer by David Hailey about 7 years 1 month ago
This a collection of descriptions I compiled while working on some system build templates and etc.
Database   Services
ConnectionDBEnables   the CUC DB.
Connection Server Role ManagerEnables   the server status when a CUC cluster is configured.
Connection ServiceabilityEnables   CUC Serviceability interface.
Critical Services
Connection Conversation ManagerEnables   CUC to handle calls.  Disabling this   service degrades CUC functionality.
Connection Message Transfer AgentEnables   delivery of messages to the message store.  Disabling this service degrades CUC functionality.
Connection MixerEnables   the audio (media stream) for calls, recorded messages, and TTS.  Disabling this service degrades CUC   functionality.
Connection NotifierEnables   notification of messages (turn on/off MWI).  Disabling this service degrades CUC functionality.
Base Services
Connection AdministrationEnables   CU Admin interface.
Connection DB Event PublisherEnables   notifying CUC components of DB changes.
Connection License ServerEnables   CUC licensing by reading the license files installed on the system.
Connection SNMP AgentEnables   SNMP which uses the Cisco-Unity-MIB.
Optional Services
Connection Access LayerEnables   sharing of user data between CUC and other servers by using Cisco Unity   Access Layer (CUAL).  This is an   HTTP/SOAP web service which can be used, for example, by Digital Networking   with Unity.
Connection CM Database Event ListenerEnables   detection of changes in the CUCM DB.
Connection Database ProxyEnables   DB replication for CUC clusters.
Connection Digital Networking Replication AgentEnables   replication of data between CUC servers in Digital Networking.
Connection File SyncerEnables   replication of files for CUC clusters.
Connection Groupware Caching ServiceEnables   CUC to cache calendar data (from Exchange, MP, and MPE) and to cache Exchange   contadcts.
Connection IMAP ServerEnables   access to CUC via IMAP.
Connection Inbox RSS FeedEnables   RSS feeds for checking voicemail from RSS clients.
Connection Integrated Mailbox ConfigurationEnables   sharing of data between CUC and CUCM.
Connection Message Event ServiceEnabes   access to voice message data on CUC by CUMA.
Connection Personal Communication AssistantEnables   the Cisco PCA interface.
Connection Realtime Monitoring API'sEnables   access to data on CUC via RTMT.
Connection Reports Data HarvesterEnables   conversion of data in log files to entries in the reports DB.
Connection SMTP ServerEnables   access to data on Connection via SMTP server.
Connection System AgentEnables   schedules for system tasks such as resynchronizing MWI's.
Connection Voice Mail Web ServiceEnables   access to data on Connection through Voicemail Web Service (VMWS) by Cisco UC   Widgets such as Visual Voicemail.
Connection Voice Recognition TransportEnables   generation and placement of dynamic grammars that are used by the speech-rec   engine for the voice user interface (VUI).
Connection Voice RecognizerThis   is the speech-rec engine that enables voice recognition for the VUI.
Hailey
Please rate helpful posts!
Overall Rating: 5 (2 ratings)
Correct Answer
David Hailey Tue, 06/15/2010 - 19:01
  • Purple, 4500 points or more
Database   Services
Critical Services
Base Services
Optional Services
Hailey
Rob Huffman Wed, 06/16/2010 - 06:54
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Hailey,
Excellent reference doc my friend!! +5 for compiling and sharing this
for others to use
I converted it to a .pdf and will save it for future use.
Thanks again!
Cheers!
Huff
Abdul Salam Wed, 03/21/2012 - 00:51
One more
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/serv_administration/guide/8xcucservag040.html#wp1057743
Table 5-1     Cisco Unity Connection Services in Version 8.x
Service
Description
Status Only Services
Connection DB
This service enables the Connection database and can be deactivated only by using the command-line interface (CLI).
This service enables the server status when a Connection cluster is  configured and can be deactivated only by using the command-line  interface (CLI).
This service enables the Cisco Unity Connection Serviceability  Administration interface and can be deactivated only by using the  command-line interface (CLI).
Critical Services
This service enables Connection to handle calls. Disabling this service will degrade the ability of Connection to function.
Connection Mailbox Sync
(Connection 8.5 and later)
This service synchronizes messages between Connection and Exchange.
This service enables the delivery of messages to the message store.  Disabling this service will degrade the ability of Connection to  function.
Connection Mixer
This service enables the audio (media stream) for calls, recorded  messages, and Text to Speech (TTS). Disabling this service will degrade  the ability of Connection to function.
Connection Notifier
This service enables notification of messages, such as turning message  waiting indicators (MWIs) on and off. Disabling this service will  degrade the ability of Connection to function.
Base Services
This service enables Cisco Unity Connection Administration and the settings that are saved in the interface.
This service enables notifying Connection components of changes to the Connection database.
Connection Exchange Notification Web Service
This service allows single inbox to receive message change notifications from Exchange Web Services-based external services.
This service enables the Connection licensing by reading the installed  license files, tracking the number of seats that are in use, and  enabling licensed features.
This service enables the Simple Network Management Protocol (SNMP), which uses the Cisco-Unity-MIB.
Optional Services
This service enables the sharing of user data between Connection and  other servers by using Cisco Unity Access Layer (CUAL), a HTTP/SOAP web  service. For example, this service can be used by Cisco Unified  Communications Manager Business Edition (CMBE) or by Digital Networking  with Cisco Unity.
This service enables the detection of changes in the Cisco Unified Communications Manager database.
This service allows tools that are not installed on the Connection  server (COBRAS, User Data Dump, Distribution List Builder, and so on) to  gain direct access to the Connection database via ODBC from a Windows  client on the network.
The service is off by default. To use any of these tools, you must  enable the service, configure the time out for the service, and create a  user that has the remote admin role. For more information, see the help  file for the applicable tool.
Connection Diagnostic Portal Service
This service enables access to data on Connection by the Diagnostic Portal in the Real-Time Monitoring Tool (RTMT).
This service enables the replication of data between Connection servers for Digital Networking.
Connection Directory Feeder
For Intersite Networking, this service checks the local site  change-tracking database for directory changes and responds to poll  requests from the remote site gateway Reader task.
This service enables the replication of files for Connection clusters.
This service enables Connection to cache calendar data (from Exchange,  MeetingPlace, or MeetingPlace Express servers) and to cache Exchange  contacts.
This service enables access to data on Connection by IMAP clients.
This service enables RSS feeds for checking voicemail from RSS clients.
This service enables sharing of user data between Connection and Cisco Unified Communications Manager.
Connection Jetty
This service enables Java web clients.
This service enables access to voice message data on Connection by Cisco Unified Mobility Advantage.
This service enables access to data on Connection by the Cisco Personal Communications Assistant (Cisco PCA).
Connection Realtime Monitoring APIs
This service enables access to data on Connection by Real-Time Monitoring Tool (RTMT).
This service enables conversion of data in log files to entries in the reports database, which is used to generate reports.
Connection REST Service
This service enables Representational State Transfer (REST) API clients.
This service enables access to data on Connection by an SMTP server.
Connection SpeechView
This service enables the SpeechView feature and communicates with the third-party external transcription service.
This service enables schedules system tasks (such as resynchronizing  MWIs) that the administrator can enter in Cisco Unity Connection  Administration.
Connection Voicemail Web Service
This service enables access to data on Connection through Voicemail Web  Service (VMWS) by Cisco Unified Communications Widgets such as Visual  Voicemail.
This service enables generation and placement of dynamic grammars that  are used by the speech-recognition engine for the voice user interface  (VUI).
This service is the speech-recognition engine that enables voice recognition for the voice user interface (VUI).
