pvlan routing issue 3750
Jun 15th, 2010
Working with a 3750 and pvlans. I cannot route to any pvlan other than the promiscuous port. As far as I can tell I have Laver 3 routing enabled….but then again it’s not working!?!
Basically I’m separating out servers from workstations through pvlans and want to use ACLs security. With the current setup I have all ip, tcp and icmp traffic allowed to any any but still not working. Cannot ping or RDP to any system outside of their pvlan.
Please help…loosing too many brain cells…save the brain cells…..!
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service sequence-numbers
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone UTC -8
switch 1 provision ws-c3750g-24ts-1u
system mtu routing 1500
vtp mode transparent
authentication mac-move permit
ip subnet-zero
ip routing
ip domain-name xxxxxxxxxxxxxxxxx
ip name-server xxx.xxx.xxx.xxx
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 100
  private-vlan primary
  private-vlan association 101-103
vlan 101
name LAN
  private-vlan community
vlan 102
name Secure
vlan 103
name Servers
interface GigabitEthernet1/0/1
switchport private-vlan host-association 100 103
switchport mode private-vlan host
interface GigabitEthernet1/0/2
switchport trunk native vlan 100
switchport private-vlan mapping 100 101-103
switchport mode private-vlan promiscuous
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust dscp
auto qos voip trust
macro description cisco-router
spanning-tree portfast trunk
spanning-tree bpduguard enable
interface GigabitEthernet1/0/6
description Adm - NIC 1
switchport private-vlan host-association 100 101
interface GigabitEthernet1/0/24
description SV01 - NIC 2
switchport private-vlan host-association 100 102
interface Vlan1
no ip address
interface Vlan3
no ip address
interface Vlan100
ip address xxx.xxx.xxx.xxx 255.255.255.0
ip access-group 100 in
ip access-group 100 out
private-vlan mapping 101-103
interface Vlan101
no ip address
shutdown
ip default-gateway xxx.xxx.xxx.xxx
ip classless
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx
ip http server
ip http secure-server
ip sla enable reaction-alerts
access-list 100 permit ip any any
access-list 100 permit tcp any any
access-list 100 permit icmp any any
Overall Rating: 4 (1 ratings)
crobenstein Tue, 06/15/2010 - 15:16
Hi Ron, if I understand your problem correctly, you can successfully connect from device to device within (say) vlan 101, but not from vlan 101 to 102 or 103.  You're using the same SVI for all of these, so they're all in the same subnet, so you wouldn't be routing between them but switching.  I'm pretty sure connectivity is barred between different community vlans so you need to go through an L3 device (SVI) i.e. you need a different SVI for each vlan for the ACLs to filter the traffic, seemingly negating the pvlan requirement.
John
beartoe1900 Tue, 06/15/2010 - 16:16
Hey John,
Thanks for the quick response..You are correct with me being able to access anything within the plvan community and the promiscuous port. I can also ping the svi ip from any pvlan but that is the end of the story. From what I understand, when using pvlans SVI needs to be setup in transparent mode and you can only setup for the primary pvlan which propagates to the secondary pvlans....still looking into it further.
"Layer 3 devices communicate with a private VLAN only through the primary VLAN and not through secondary VLANs. Configure Layer 3 VLAN interfaces only for primary VLANs. You cannot configure Layer 3 VLAN interfaces for secondary VLANs"
3750 manual page 471
beartoe1900 Fri, 06/18/2010 - 17:56
For all others that are ripping out their hair on layer 3 communication on pvlans without having a router that can proxy arp......after 5 days of pain
What needs to happen is local proxy arp and ip proxy arp both needs to be enabled on the primary pvlan interface. After that ACLs will control traffic between community pvlans.
peace out!
Related Content
