How to access the MIB on DMP 4400g w. #5.2
aboross12
We replaced our 4305 with a 4400g, using the latest software version #5.2
According to the DMP's manual you can access the MIB on the DMP by http://<ip.address>:7777/get_param?p=xxxxxx
The 4400 does not return anything.
Is any idea out there, what is the reason?
Andras
This works fine for me...
Which web browser are you using?
Is there are firewall between you and the DMP?
Is there are firewall between the DMM and the DMP?
this is the same command the DMM sends to the DMP...
T.
8 Replies 8
chaitanya_datar
If you are trying to access the DMP 4400 having the version 5.2 you need to use https instead of http. Try the following command and it should work.
https://:7777/get_param?p=xxxxxx
I tried and it failed. It timed out w/o ever asking for id/pw.
Is there any way to provide the id/pw together with the GET?
Andras
Try this example and see if it works...
  https://admin:default@a.b.c.d:7777/get_param?p=init.version
  admin   = DMP Web Account Username
  default = DMP Web Account Password
  a.b.c.d = IP Address of DMP
Your URL test did not include the user\password...
T.
I get the same answer > times out.
Have you tried it?
(I do not know if the https port is open or not via my firewall), Could it be an issue?
T.
Are you using the DMPs in Standalone or managing them through the DMM?
If the later, you should be able to get a dump of the mib by doing the System Task of Status on a selected DMP.
Richard,
Thanks for the follow up. The problem was resolved by using https vs. http. Since the 4300 accepted http, I tried the same method as I used earlier.
Andras
