spa8800 failover to analog line?
Jun 15th, 2010
Hi there, i am trying to set up the following system
analog commander pbx ---> linksys8800 ---> internet
it seems to work fine when the internet is connected, but i would  like it to failover and kick back onto the old ptsn line when the net is  down.
i know this is possible with an asterix server but i dont know  how to configure a normal old line on the spa8800? when i pull the  ethernet cable it just sounds engaged.
i hope this is possible.
im a bit of a newbie as you can probably tell!. thanks in advance for  your help.
