spa8800 failover to analog line? (not asterix)
Jun 15th, 2010
Hi there, i am trying to set up the following system
analog commander pbx ---> linksys8800 ---> internet
it seems to work fine when the internet is connected, but i would  like it to failover and kick back onto the old ptsn line when the net is  down.
i know this is possible with an asterix server but i dont know  how to configure a normal old line on the spa8800? when i pull the  ethernet cable it just sounds engaged.
i hope this is possible.
im a bit of a newbie as you can probably tell!. thanks in advance for  your help.
mrdogantr Wed, 06/16/2010 - 02:18
Voice tab > Line page >
VoIP Fallback to PSTN section (SPA3102 and SPA8800)
On the SPA8800, these settings are configured on the Phone pages only.
Auto PSTN Fallback : If enabled, the ATA device automatically routes all calls to the PSTN gateway when the Line 1 proxy is down (registration failure or network link down).
The default is yes.
hope this helps
visualplayground Wed, 06/16/2010 - 18:13
thanks very much for your help. it seems to be half working but i  sitll have an issue wth the net side of things,
When  the power is removed from the spa8800 it failsover to the ptsn line  well,
but when i remove just the ethernet, it doesnt want to  failover, just gives me an engaged signal... any ideas?
i  have set the following settings to the line page thinking this might  help but doesnt seem to change.
Make Call Without Reg: yes
Ans Call Without  Reg:  yes
Register:  no
All i am getting is an  engaged signal when the net is down..
i assume it  doesnt need to register with a device as it is analog.
is there  something i am missing here?
thanks very much for your  help. almost there!
