06-16-2010 01:53 AM - edited 03-15-2019 11:15 PM
I knew about a link that would display the screen of a remote phone in my web browser.
But I have lost it.
Any one knows the link?
JH
06-16-2010 02:25 AM
Some tips:
1) It's cAsE Sensitive!
2) The user you specify must be associated to the phone - error 4 means auth error, which could be password or not associated
3) Error 0 generally means mistyped URL..
Aaron
Please rate helpful posts...
06-16-2010 02:31 AM
Yep that was it,
Thank you very much
Jan
06-16-2010 03:14 AM
Hi Aaaron,
Does this work with all phones?
I have tried it with a 7940 running 8.1(1.0) on CUCM 7.1(2) and get the XML page below after entering the credentials:
06-16-2010 03:46 AM
Hi James
It is (adopting my best Cisco TAC voice) 'working as designed'.
The older model phones use a rather natty little format called CIP for images. That string of FF etc data is what the phones understands as an image.
Newer models return PNGs instead, which IE understands and will display (so 7941,42, 45, 75 etc, anything java-based).
You can convert the CIP data to a GIF using tools from the IP Phone Services SDK...
Aaron
06-16-2010 04:00 AM
That's a great info! +5 for Harrison!
Does it work for CME as well? Also, any other link to control the phone as well (I know this is overwhelming while expecting this!)?
06-16-2010 04:07 AM
Well - yes, it is possible to control the phone, but not via IE easily. You need to post XML objects (CiscoIPPhoneExecute objects to be precise if you are looking at the IP Phone SDK) to the phone web server at http://phoneip/CGI/Execute, for example:
Would cause the phone to dial that number... it's all detailed in the SDK if you are interested in pursuing it.
Otherwise http://www.voipintegration.com/UCSoftware.aspx - these guys have a remote control based around these functions, it used to be free but now they want money. There is a trial though...
Aaron
06-16-2010 04:10 AM
Thanks Aaron, +5
06-16-2010 04:20 AM
Ah - yes, the screen grab works on CME too... it's a function of the phone firmware.
The phone will authenticate the user ID you use against CME, so it would have to pass authentication there.
