06-16-2010 01:55 AM - edited 03-19-2019 01:05 AM
Hello
I have a problem in getting the CUPC client application to register with the CUPS server. I have successfully integrated CUPS with the CUCM7 which is again on AD. However when I try to login to the CUPC client, it works only as a softphone and all other features are greyed out. I checked the compatibility matrix and all three should work.
The Publisher status shows all green
Incoming Access list specified as all all in Presence
Attached are the screenshots. Please help me with this. I have a demo to present to a client on friday. Have been trying to figure this oout for many days.
Thanks in Advance.
Abraham
06-16-2010 08:19 AM
The biggest concern is the red X next to Presence in the client 'Server Health' screen. From the log you included, it looks like the client is unable to resolve the address of the CUP server. It could also be blocked by a firewall or acl, if I'm misreading it. But I would definitely start by trying to ping the CUPS address from the client by name and/or using the FQDN in the server field when logging into the CUP client.
06-16-2010 12:04 PM
Thanks ccharlebois ,
Your solution partially worked.. Now I am able to see the status of the user logged in... However still the chat button is greyed out..
Attached is the screehshot.
06-16-2010 12:19 PM
Don't worry about secure messaging... Unless you are using Secure Messaging within Unity or Unity Connect. It's not something I've played with, so I have no experience troubleshooting it.
As for the TFTP error, have you defined the phone for the personal communicator with a device name of UPC
06-17-2010 07:49 AM
Hi Abraham,
From your screen shots, the issue looks like CUPC configuration file is not getting downloaded from CUCM.
Can you check the following?
1. did you create the end user in LDAP with all in upper case (Eg.CUPUSER2). Your screen shot shows that the user id is in all lower case.
2. Did you create CUPC phone device in CUCM with Device name starts with UPC followed by endusername (Eg. UPCCUPUSER2)?
3. Can you check the TFTP server configuration in CUP admin Page?
Sumin
06-17-2010 08:08 AM
If it were issue #1, the user wouldn't be able to login at all, so that isn't the problem. And issue #3 is only a potential problem with CUPS 1.X and 6.X. CUPS 7+ uses AXL to populate the TFTP field, it seems.
It's either that the softphone configuration wasn't setup, or, more likely, based on the logs, that traffic to or from the TFTP server is being blocked.
ERROR LCMiddleware - (MWMSG_CFGMGR_PARSEFAILED) TFTPConnectionImpl::connect() - Failed to download UPCCUPUSER1.cnf.xml
DEBUG LCConnection - CALLMANAGER_TFTP reportResult(DISCONNECTED): reason=UNREACHABLE, functionality=NONE
Hope this helps. BTW, please rate posts if they are helpful.
06-17-2010 09:19 AM
I will do a packet capture while trying to login to the CUPC and figure out this. Will update you with the results.
06-20-2010 12:07 PM
06-20-2010 12:52 PM
The "handset" icon next to the contact "CUP 2" indicates he is NOT a presence user thus not having IM capabilities.
For a step-by-step feature configuration guide, please take a look at: http://www.lulu.com/content/5552336
Michael
11-01-2010 05:10 AM
Hi Abraham,
Were you able to solve the TFTP issue? I have the same issue but only with some of the Users' PC/Laptops. When I try to access those users from my laptop it works fine. It seems their personal Firewall or some other network policy is blocking that Laptop to connect with TFTP server.
Would you please let me know what did you do as a workaround for the same? Thanking you in anticipation.
Amit.
