2901 Router - Traffic shaping
brunstadnett
Hi all!
I have a Cisco CISCO2901/K9 router which I'm using as a Internet gateway.
The question: Is there any possibilities to control / shape the inbound traffic, so that I can reserve an amount of the bandwidth for a single VLAN?
I'm using a streaming solution on one VLAN, and the other VLAN is the public inside. I want to reserve bandwidth to the streaming VLAN.
7 Replies 7
You should be able to use traffic policing to accomplish this. This is decent link that explains the difference between shaping and policing.
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800a3a25.shtml
-Todd
Hi Todd!
I've now read the document. It is only theory and not a practical config example.
Any one who has experience applying this in real life?
I need to guarantee the download speed (inbound) for a certain VLAN or a single host would also be sufficient.
access-list 101 permit ip
access-list 102 permit ip
class-map match-all 40MEGS
match access-group 102
class-map match-all 10MEGS
match access-group 101
policy-map POLICE
class 10MEGS
   police cir 10000000 bc 1875000 be 3750000
     conform-action transmit
     exceed-action drop
class 40MEGS
   police cir 40000000 bc 7500000 be 15000000
     exceed-action drop
int gix/y
service-policy input POLICE
Verification
show policy-map interface gix/y
Hitesh Vinzoda
Pls rate useful posts
The config you posted, is a policy. Will the "exceed-action drop" cause traffic drop or lag in connection, or will the source just resend the packet?
What will the "police cir 10000000 bc 1875000 be 3750000" values be, if I have a slower connection? How is the bc and be calculated?
Will the limited interface be able to use the full bandwidth when not in use by the prio int?
Shouldn't you apply the service-policy to the prio interface? Or is this defined by the ACL in the top? 101 is destination VLAN10 and 102 is destination VLAN20.
As you can not do traffic shaping inbound on an interface, so other way we can police the traffic which is not critical or can be dropped if they exceeds the specified rate...
cir is the rate at which you want to police or drop the traffic.. Bc is the committed burst and Be exceed burst...
there are values recommended by cisco for Be and Bc which are mentioned as below
Bc = configured rate * (1 byte)/(8 bits) * 1.5 seconds
Be = 2 * normal burst
e.g
you want to police some traffic at 512 kbps than Bc = 96000, Be= 192000
The traffic that you want to police should be identified by ACL
match ACL's in class-map
in policy map
call the class-map
and police the traffic at desired rate
apply the policy on the interface inbound
for other questions .. please rephrase it as im not able to understand  what you meant to say
Hitesh Vinzoda
Inside host that I want to prioritize: 10.0.0.10
Inside net that needs to be policed: 10.0.1.0
Outside interface 123.123.123.10
Could an ACL then be like this?
access-list 101 permit ip 10.0.0.10 0.0.0.255 123.123.123.10 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.255.255 123.123.123.10 0.0.0.255
You want it to police when they coming in from the internet
so access-list would be for policing the traffic
access-list 101 permit ip any 10.0.1.0 0.0.0.255
Hitesh Vinzoda
Pls rate useful posts.
