Pings to host successful, but trace to host fails?
Jun 16th, 2010
Attached is the switch configuration, show arp | include Vlan8, and output from my ping/trace for hosts on Vlan 8.
On my 6506-E I can ping all the hosts on vlan 8. However, there are some hosts that I can successfully trace to without problems, while other host on the same vlan I can't. I'm having the same problem with hosts on other SVI. What could be causing this issue? Is it normal? Thanks in advance.
TODD RIEMENSCHNEIDER Wed, 06/16/2010 - 05:37
Well if you can ping them I think that would test layers 1 through 7. Sounds like it could be host based filtering.
Ganesh Hariharan Wed, 06/16/2010 - 08:00
It can be possible that those host are having inbuild firewall which can be blockng icmp packets by the systems.
Ganesh.H
gatlin007 Wed, 06/16/2010 - 14:02
Remember trace route works by sending a UDP packet with a small ttl expecting network devices to send icmp unrachables back to the originating host.  If there is no firewal in the path try removing the following command on the affected SVI’s
no ip unreachables
Chris
