ISDN E1 channels
Jun 16th, 2010
G
ood afternoon,
I've a little issue with the synchronization of my E1 channels. In fact, I've 2911 router with an E1 controller connected to the PSTN provider. The GW is registered in MGCP - great this works.default my
By default my voice channels are from 1 - 15 and 17 - 31 but I really need to synch with our PSTN provider 1-30 channels. So I changed the Channel IE Type to Continuous Number.
But when I do some debugging on the gw with sh voice call summary, the channels are not well configured. It stays always in 1 - 15 and 17 - 31.
Could you please help me?
Aaron Harrison Wed, 06/16/2010 - 05:37
  • Community Spotlight Award,
    Member's Choice, May 2015
On an E1, channel 16 is ALWAYS the D-channel used for signalling.
So you cannot change this - and you don't need to. When somoeone refers to 'channels 1-30' they generally mean 'B-channels 1-30'.
All is well, so put your feet up.
Aaron
Please rate helpful posts..
martin.schoonbroodt Wed, 06/16/2010 - 08:21
Thanks for the information.
But tell me why I have not the same channel that is synchronized between
the Nortel GW and the Cisco GW.
Let's say a call is coming in on channel 1, I do a sh voice call summary and
I see channel 1 as well like usual.
When we arrive on channel 16, I can tell you we
are not anymore synchronized.
For instance, a call is coming on channel 26, I do
a voice call summary, I see channel 26 is busy. But the Nortel engineer say he is using channel 24. We have always this issue only when we are above the 15th channel.
I really don't understand. LOL
We have the calls OK when we are below 15 so I think the signaling is well working. What kind of Channel IE type do I need to setup?
paolo bevilacqua Wed, 06/16/2010 - 11:37
  • Hall of Fame,
    Founding Member
Send configuration and "debug isdn q931" with "term mon" when you receive a call with troubloe. Also explain exactly what is happing.
