VPLS - Implementation
Jun 16th, 2010
Hi Team
Can someone advise me on a basic VPLS implementation. i.e. the configurations on the PE's and P nodes and customer CE devices. CE device's will be routers. Its for a single customer. The requirement will be for 8 sites.
But for now i just need an overview of how to implement VPLS over MPLS technology.
I've tried to make this post as simple as possible, my previous posts I think went into to much detail.
C Williams
Overall Rating: 5 (1 ratings)
judebryant Thu, 07/15/2010 - 07:51
C Williams,
there are many documents on Cisco's website covering this subject.
I use vpls within my P core network using a manual configuration.  ie lets say you have 8 routers in a mesh and you want to create a vpls instance for vlan 400.
Using ES20 cards on a 7600 router the configs look like this.
R1
l2 vfi vlan400 manual
vpn id 400
neighbor ip-address(R2)
neighbor ip-address(R8)
each neighbor statement creates a l2 connection from R1.  Do this on all routers.  Thats it
you can also us iBGP to make this an auto connection.
Be aware if you are not using the ES20+ cards and SRE, MAC learning occurs with the xconnect statement.
The new configuration uses 802.1ah or MACinMAC so all the MAC address for a specific location is represented by 1 MAC address.
Jude Bryant
Network Engineer
Pioneer Telephone
