Shorcut command on router?
Answered Question
Jun 16th, 2010
When I'm on our main router I might need to telnet to a number of routers from that during that session, rather than me typing "telnet 192.168.1.1" etc etc is there a way I can craete a short cut so I might just type "r1" for router 1 and it telnets to the router?  I guess I could use the "ip host" option.
Correct Answer by burleyman about 6 years 11 months ago
You could create this alias
config t
alias exec r1 telnet 192.168.1.1
that should work.
Mike
Overall Rating: 5 (1 ratings)
Correct Answer
burleyman Wed, 06/16/2010 - 08:28
  • Blue, 1500 points or more
config t
that should work.
Mike
Ganesh Hariharan Wed, 06/16/2010 - 08:37
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
To define a static host name-to-address mapping in the host cache, use the   ip host global configuration command. To remove the    name-to-address mapping, use the no form of this command.
ip host name [tcp-port-number] address1 [address2...address8]
Config# ip host ROUTER_NAME INT_Address
Example: ip host lab-a 192.168.5.1
or Config# ip host RTR_NAME INT_ADD1 INT_ADD2 INT_ADD3
Example: ip host lab-a 192.168.5.1 205.23.4.2 199.2.3.2 - (for e0, s0, s1)
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
