IOS Upgrade
Answered Question
Jun 16th, 2010
We have an ASA 5550, running 8.0(5).  Would you recommend that we upgrade to IOS 8.2 or 8.3?
Thanks.
Laura
Correct Answer by Federico Coto F... about 6 years 11 months ago
Laura,
Normally if the ASA is running fine (no problems) it is not recommended to upgrade.
In case you require an additional feature or functionality incorporated in versions 8.2 or 8.3, then obviously you should upgrade.
But, 8.0(5) is very stable and if there are no problems, I will suggest to stay with it.
Keep in mind that 8.3 consumes a lot more of memory.
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Wed, 06/16/2010 - 10:49
  • Green, 3000 points or more
Laura,
Federico.
