Will SNMP trap on a port channel member that is up/down?
Jun 16th, 2010
I have an issue with an interface that did not generate a ticket in our system when a member of a port channel went to up/down (line up, protocol down)state, as far as I can tell everything is configured correctly as far as SNMP goes, and I did confirm that a ticket was generated (SNMP trapped) when the interface went to a down/down state. My question is, is this default behavior? I have seen the issue in two separate machines. If it is normal behavior is there anything I can do to allow the interface to trap in an up/down state? Details below, thanks!
#sh int gi6/2
GigabitEthernet6/2 is up, line protocol is down (notconnect)
#sh int status | i 6/2
Gi6/2   To #############  notconnect   routed        full   1000 1000BaseSX
#sh run int gi6/2
Building configuration...
Current configuration : 120 bytes
interface GigabitEthernet6/2
description To ############# ge-7/0/1
no ip address
channel-group 2 mode active
end
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps config
glen.grant Wed, 06/16/2010 - 17:06
  Make sure on the ports you have " snmp trap link-status" on all ports
and even on the  port channel SVI .  This should trap if the ports or the entire port ch
annel go down.
mb5825123 Thu, 06/17/2010 - 06:32
Thanks will give it a shot, isn't this a setting that is supposed to be enabled by default? Will see if explicitly enabling it on the interfaces makes a difference.
