ASA 5505 VPN is not responding.
Answered Question
Jun 5th, 2010
Here is the asa 5505 Configuration. VPN is not responding. When I check my IP address in the website "whatismyip.com" it is showing A.B.C.X.    I believe it shoud be A.B.C.A.  Also I am not able to access (https://A.B.C.A) firewall from public untrusted network. Please help .
siva
Correct Answer by Marcin Latosiewicz about 6 years 10 months ago
Sivakumar,
Could it be that your ISP is doing some sort of proxy or NAT for some connections - like http you mentioned?
A simple packet capture on ASA will show you if the ASA is receiveing those packets.
Marcin
Overall Rating: 5 (1 ratings)
Correct Answer
Marcin Latosiewicz Sun, 06/06/2010 - 00:16
  • Cisco Employee,
Sivakumar,
Marcin
sivapkd100 Sun, 06/06/2010 - 00:36
Can you please tell me the packet capture procedure?
Thanks.
sivapkd100 Wed, 06/16/2010 - 11:39
The problem has been figured out. Firewall configuration is correct. But there was a small coniguration missing in netopia router, i.e, I had to turn off NAT functionality. Now all right.
Thanbks for responding to my thread.
Related Content
