Sup V-10GE question
Answered Question
Jun 16th, 2010
I have 2 Sup V-10GE in each of my C4507R-E switches. They are in SSO mode. Te3/1 is connected. Te 4/1 is connected. Te3/2 is inactive. Te 4/2 is inactive.
Can I use Te 3/2 and Te 4/2 in channel mode for a Nexxus switch uplink?
I have 2 of these C4507R-E as my core switches and will want to do the same identical setup to the 2nd core switch
Correct Answer by Viral Bhutta about 6 years 7 months ago
Thats is correct.
Check This out
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/52sg/configuration/guide/RPR.html#wp1097897
When you select 10-Gigabit Ethernet uplinks on WS-X4516-10GE and WS-X4013+10GE Supervisor Engines in RPR or SSO mode, only TenGigabitEthernet 1/1 and 2/1 interfaces are available. Similarly, when you select Gigabit Ethernet uplinks, only GigabitEthernet 1/3, 1/4, 2/3, and 2/4 interfaces are available. When you select to use both uplinks concurrently, TenGigabitEthernet 1/1 and 2/1 interfaces and GigabitEthernet 1/3, 1/4, 2/3, and 2/4 interfaces are available.
Hope this helps.
If I am not wrong then
Dual uplinks are supported in the following modes of operation:
1) If there are two sups in the device, you can have the first TenGig of
each sup active and acting as an uplink.
or
2) If there is a single sup in the chassis, then two interfaces on the same
sup would be active and acting as an uplink.
You cannot have dual uplinks on a single sup active when dual sups are
installed in the system.
Overall Rating: 5 (3 ratings)
Correct Answer
Viral Bhutta Sat, 06/19/2010 - 19:46
or
Correct Answer
Viral Bhutta Sat, 06/19/2010 - 19:50
Check This out
Hope this helps.
rzulueta315 Mon, 06/21/2010 - 14:35
Thanks for the replies. Since I do have it in SSO mode I can only use Te 3/1 and Te 4/1.
