How to block specific calling numbers on SIP voice GW?
Jun 16th, 2010
Hi all,
As per the call flow below, is any way to block specific calling numbers on SIP voice GW or CUCM 7?
( I could see H323 is capable, not sure about SIP voice gateway)
PSTN -> digital T1 ->SIP voice gateway -> Cisco Call Manager -> corporate user
Thanks in advance,
CHRIS CHARLEBOIS Wed, 06/16/2010 - 11:59
What hardware is running the SIP gateway?  If it is IOS, can you run a TCL script on it, like on an H.323 gateway?
CHRIS CHARLEBOIS Wed, 06/16/2010 - 12:29
I think you can use the TCL script that blocks a list of calling numbers.  It's one of the sample voice TCL scripts over on the Cisco Developer web site.
Paolo Bevilacqua Thu, 06/17/2010 - 10:31
How many numbers you need to block ? For less than 15, you can use a translation-rule with to refuse calls under the incoming voip DP.
qinghao.zhou Sun, 06/20/2010 - 13:57
thanks all for your reply.   Only one phone number I need to block.
I made change to voice gateway, still not working.  I attached the change I made below.    Anything I missed?
voice translation-rule 1
rule 1 reject /XXXXXXX/
voice translation-profile call_block
translate calling 1
dial-peer voice 100 pots
call-block translation-profile incoming call_block
destination-pattern 9T
incoming called-number .
port 0/0/0:23
qinghao.zhou Sun, 06/20/2010 - 21:16
I tried, still doesn't work.
Also, I added the translation profile to voice port, the call still goes through.
voice-port 0/0/0:23
input gain -6
output attenuation 6
Any idea?  Any more information I could gather for troubleshooting?
I run " debug isdn q931" ,   it showed the correct calling number which I want to block,  (  eg.  rule 1 reject /1234567890/ ,    tel#1234567890 is the number I want to block)
Thanks a lot!
