Unity 5 RollUp
Answered Question
Jun 16th, 2010
Recently I have download from Cisco site CU5.01ES85RollUp.exe (ES85). Today I have download the readme but when I was doing the upgrade I shocked that the readme file is for CU5.01ES83RollUp.exe (ES83). I checked Cisco site but the strange issue the no CU5.01ES85RollUp.exe (ES85) in the site. The question is where is CU5.01ES85RollUp.exe (ES85)? Where is the readme file?How to uninstall?
Correct Answer by David Hailey about 6 years 10 months ago
Here's your solution: Unity 5 ES86 was just released and is available for download.  It fixes issues that were found in ES85.  Here is a link to the release notes:
http://www.cisco.com/web/software/282074319/34756/CU5.01ES86_Readme.html
Hailey
Please rate helpful posts!
Yes, in another thread I was discussing a user's recent attempt to move to Exchange 2010 by jumping the gun a bit so to speak.  He confirmed that he downloaded ES85; however, it had subsequently been removed.  The procedures are fairly uniform between ES releases; however, there may be something gong on that we are not yet privy to.  The roll-up read me typically contains uninstall instructions - I believe you could use those to remove ES85.  However, if you are not experiencing any issues then it may be best to leave things as they are until a subsequent patch is released.
Hailey
Overall Rating: 5 (3 ratings)
Correct Answer
David Hailey Wed, 06/16/2010 - 14:49
  • Purple, 4500 points or more
Hailey
abu_khair Wed, 06/16/2010 - 22:59
Thank you for your reply.
I read ES83 to do the Uninstallation procedures but it is not applicable on ES85. ES83 instructed me to run restore.bat but this file does not exist on ES85.
abu_khair Fri, 06/18/2010 - 07:11
Thank you for your help. Your posts are helpful
Giovanni Ceci Sat, 04/16/2016 - 11:35
Would anyone here happen to have the latest possible ES for 5.0.1 or at least ES86 as I have a client trying to do Exchange 2010 integration with their Unity servers. The download is no longer available on Cisco's website. I think the latest one is CU5.01ES89RollUp.exe.
If anyone has it, can you let me know and perhaps dropbox it? Would be much appreciated.
John
