SPA525G - FW 7.4.4 Bluetooth headset problem
Jun 16th, 2010
I am using a Plantronic Voyager PRO or Nokia HS-36W headset.
Parring is ok as well as call pick-up and release.
But after some use it drops calls at pick-up.
It also goes from BT headset (blinking headset lamp) to headsset jack (steady lamp) at pick-up.
Only a power recycle of the SPA525G will recover for BT headset use.
To me it clearly seems to be a FW bug.
Any views?
Flemming, Denmark
Alberto Montilla Mon, 06/21/2010 - 02:35
  • Cisco Employee,
Dear Sir;
Yes, we have detected the bug. We are working for a resolution on this subject (new FW). As soon as available (dont have an estimate yet), will let you know
Alberto
Alberto Montilla Wed, 10/20/2010 - 16:42
  • Cisco Employee,
Dear Sir,
Please download and use 7.4.6, it should solve your issue. SW is available on cisco.com
Alberto
SteelSmithInc Wed, 07/14/2010 - 07:10
I have the same issue with the Bluetooth Headset.  I can work around this by unpairing the phone and re-pairing the headset with the phone. I have to do this when my multi-point headset answers another phone, or go out of range.  A reboot is not necessary though.  You can go to to bludetooth configuration, bluetooth profile, option, unpair | then option, pair.  This is the quickest way.
Michael
