Need some information for IOS upgrades
Answered Question
Jun 16th, 2010
I can't seem to find a page where they'd put clearly the requirements for IOS upgrades. If I understood correctly, each Cisco device can upgrade to a higher IOS version, depending on the amount of DRAM and Flash installed. My first question is, are you able to say that to install IOS 12.4, you need X amound of DRAM and Y amount of Flash for any Cisco device? Or, does the memory requirement vary for each specific device? If it is the former, I can't a page that list those requirements. If it is the later, I can't easily find a page for each device that list the requirement for the updates.
Correct Answer by Kevin Brennan about 6 years 8 months ago
Hi Feng,
All of the requirements can be found in the Feature Navigator pages.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Kevin
Correct Answer by Jerry Ye about 6 years 8 months ago
"are you able to say that to install IOS 12.4, you need X amound of DRAM  and Y amount of Flash for any Cisco device?"
No, you cannot just assume that across all the platforms. For example, for 12.4(24)T3 Advanced Enterprise Service
7200VXR NPE-G2 1024D/256F
7200VXR NPE-G1 512D/64F
3800 512D/128F
2800 256D/128F
All the memory information are listed in the software download page for their Flash and DRAM requirement.
HTH,
jerry
Overall Rating: 5 (2 ratings)
Correct Answer
Jerry Ye Wed, 06/16/2010 - 20:14
3800 512D/128F
2800 256D/128F
HTH,
jerry
feng.lian Wed, 06/16/2010 - 23:44
Ok thanks. I guess I'll have to look at every IOS image and
build my own table.
